Natural Gas line - pressure test
I've replaced a length (14') of gas pipe with "black" gas pipe.
Gas is on and passed the soap bubble test.
I also want to do the air pressure test.
Is this the procedure:
1) Gas off
2) Disconnect meter from incoming gas line
3) Connect gas pressure gauge to incoming gas line
4) Close all valves that preceed appliances (range, oven, WH, Furnace, Clothes dryer)
5) Add 10 lbs air pressure at the pressure gauge
6) Wait 6 hours - check results
7) If pressure is less than 10 lbs - repressurize and soap test.
I have also read that the appliance(s) should be disconnected before the test. Is this to protect the appliance in the event the inline valve fails?
1) Gas off
All in the list sound good. Personally, I would just soap test, then do it again in a couple hours. Give it some time to push any dope or tape out. Whatever you feel comfortable with. Good job!
That is the procedure for pressure testing new gas line, however, the time and pressure varies depending on the AHJ.
It not a bad idea to disconnect the appliances when testing in the event of a valve failure. Additionally, there are many styles of valves out there. Don't use a 5 psi rated valve when testing @ 10 psi.
there is no point since the gas pressure to your house should not be more than 2psi unless you have a red faced meter, at least in my area.
but whenever making any repairs and definately adding (since adding should entail a permit and inspection) testing the whole system is a very good idea.
there have been a lot of gas explosions the last few years. gas is the one thing that does not allow even 1 mistake when installing it.
Inspector came by, said it all looked good but needed to be pressurized to 15psi and he'd come back and look at it. Went ahead and purchased the gauge, filled it with 15psi... and the 60' or so lost all pressure within about 5 minutes. Took about 8 hours of tightening, disassembling, and retightening to pass the pressure test.
Lesson learned... just because soap bubbles don't form at the ~2psi of gas pressure doesn't mean it's not leaking!
actually you may not even have had 2psi on it with just the gas on, that would be a maximum it would be. but it is to be tested to 1.5 times the working pressure by most codes and who is to say which working pressure since the gas company may be running 5-60 psi. but 15 is the norm for a high pressure sure line thus the requirement for 15 psi test. your line would probably have never leaked with just normal gas pressure.
remember gas is the one thing that doesnt allow for mistakes and so you can never be to safe with the installing/repairing of gas systems. pressure testing must be done to ensure it is as safe as possible.
you would not believe how many older lines have slow leaks that have developed over the years and that the smell disapates before getting to where someone can smell it until its to late. for almost every gas explosion someone is reported to have said they smelled gas but no one ever bothers to call anyone until something has actually blown up
pressurizing with air
I know this is an old thread, and I am going to come off as a dumb blonde but in all I've researched on testing gas lines with air the part I want to know is missing. What on earth do use to hook up your air hose to your 1" black iron pipe? It has all said, "Hook up your (compressor) to your line and pressurize." ???!!!
I have a Shrader type valve on the end of a normal air compressor hose to connect with a 1 inch new empty stubbed out & capped black iron pipe (male). Any help? Or did I miss it? Thank you, L
You can buy a 1/4" IPS x schrader (tire valve) fitting and a 1" x 1/4" IPS reducer and screw that on to your 1" pipe.
Amazon.com: Air Intake Valve: Home Improvement
I'd recommend something like this:
Larsen Supply Co 13-1891 15PSI Gas Test Gauge - Plumbing & Heating - Septic Tank & Cesspool Equipment - Pressure Gauges
It provides both the pressure gauge as well as the schrader valve all in one!
I have just changed over from propane to ng. the plumber put 3psi in the line and came back the next day (after the inspector) and pressure was @ 2.5 psi, he said it was normal for a system to lose 1/2 lb over 24 hrs. IS this normal? or is he just blowing me off?
Received 38 Upvotes
Depending on the temperatures when he pumped it up to 3 psi and then later when the gauge read 2.5 psi it could entirely normal. If he pumped it around noon to maybe four in the afternoon and then the ambient temperature dropped 10 or 20 degrees overnight and the gauge read 2.5 psi the next morning it was definitely normal.
thanks again.
