freezing underground downspout
All the downspouts on my house lead to underground downspout extender that then pops back up from the ground a few feet away. I like in norther illinois and none of the underground extended a deep enough to avoid the frost line. So they all have ice and have froze. With the warmer weather the snow is melting off of the roof, only to get stuck in the frozen pipes. My neighbors also have this problem. How can I solve this?
Welcome to the forums.
I run into the same problem every year. Other than disconnecting the downspout from the underground line there isn't much you can do. You can't stop the line from freezing underground.
Ya, bad design.
For this spring, PJ's suggestion is about all you can do. Even if you manages to melt out all of the existing ice, the pipes are still passing through frozen ground and would most likely re-freeze until the ground thaws.
Water from the roof or direct rain needs a surface solution along with drainage. Most homes here in Maine have discovered that gutters and leaders don't survive the melt and ice from the roof anyway, so most just slope the land well away from the house. Your landscaping may require another solution, like a seepage pit well away from the house, keeping all pipes below the frost line.
Another factor for the pipes freezing is the melting snow from heat in the attic producing a trickle of water when it is below freezing out.
Bud
Bud
I've only seen trenches and french drain pits on that certain DIY show out of Boston ;-)
No doubt that's the Best Practice but around here it seems we all just deal with the few days of water bubbling out of the collar the downspout fits into.
I usually disconnect my underground discharge and dump it on the ground away from the house. If we have an early snow cover, I continue to use underground since the snow does a good job of keeping it flowing. - I have about 30' of pvc to my side-hill discharge and not the corrugated black plastic that never seems to as carry as much water. - By dumb luck, this year, I did not use the underground and we did not have more than about 6" of snow cover, so the frost went deep.
Dick
Dick
The downspouts on my shop and about half of the house have simple extensions onto the lawn, and the other half of the house is as Dick described, buried 4" pvc that discharges downhill about 20-30 feet from the house. All is well for about 50 weeks of the year. The remaining two weeks, when the snow on the roof starts to melt, and the discharge is covered with whatever snow we have that year, about 12-18" this time around, the buried discharge freezes and backs up. So I disconnect the downspouts from the buried pipe and slip on an extension that dumps the water onto the yard. Not as pleasing to the eye, and couldn't mow around them, but I will remove them in another week or two and reconnect to the buried line.
I've read that "hard piping" the downspouts into the underground pipes is a no-no for this reason. Instead, the best practice would be to have the downspouts discharge into a grate-covered catch box/catch basin at the ground level, which then feeds the pipes. I intend to do this upgrade this year.
downspout catch basin - Bing Images
I don't see how that solution is much better. A decent snowfall will cover that spout and will still become a pillar of ice. When the sun does thaw the pipe, the grate will still most likely be frozen and the water can find a way into the house.
My solution this upcoming year, since I had to deal with snow-buried (frozen) downspouts is to cut the downspouts off three feet above ground level and replace as normal for most of the year. Once the snow falls, I'll remove the lower three-foot section and run the extension from that three-foot point out above the snow (adjusting as needed after (during) each blizzard).
