Honeywell to Trane Thermostat Conversion Delema
First let me say that I dont consider myself a stoopid man but I need some help converting my thermostat from a Honeywell to a Trane. The Honeywell I am replacing is a T874G1246. This unit has worked fine for too many years and it is ready for an upgrade. The unit I am going to replace it with is a Trane TCONT600AF11MA.
So my delema is I looked at the wiring for the Honeywell and it looks like this ...
Honeywell T874G Installation Instructions For The Trained Service Technician (Page 4 of 12) ...
The Trane looks like this ...
Trane TCONT600AF11MA Programmable Comfort Control PDF - edoqs
Now this is the first time I have tried to do this so any help figuring out which wires go where would be an immense help.
Welcome to the forums.
You need to post here what color wires are currently connected to what terminals on the Honeywell thermostat.
Like:
red > R
white > W
green > G
etc......
Like:
red > R
white > W
green > G
etc......
All the spec...
OK.....The Furnace is a...
Temp-Star
MFR # NBCM024XKB2
Style # BUA24A
The Heat Pumpe is a ...
Goodman
Model # CPE24-1AB
The wiring on the existing Thermostat is as follows.
G is Green
R is Red
X is Black
E and W2 are connected with a Lt Blue Jump wire and with a White wire
Y is Yellow
O is Orange
W3 is not connected
Hope this helps!
Temp-Star
MFR # NBCM024XKB2
Style # BUA24A
Goodman
Model # CPE24-1AB
G is Green
R is Red
X is Black
Y is Yellow
O is Orange
W3 is not connected
Hope this helps!
