Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Thermostatic Controls
Reload this Page >
Forced hot water and Central Air Conditioning on the same thermostat?
Old 02-27-15, 05:26 AM
W
Hi,
I bought a house that has forced hot water (fueled by oil) for heat and has a central air conditioner. They each have their own thermostat. I would like to consolidate them to one, is this doable? I have seen people seeing issues where the thermostat will turn on the fan from the AC unit in the winter when calling for heat. Obviously I would only be using one system at a time seasonally so if its as simple as switching to a different mode for the season thats fine. The motivation here is that I have a wifi thermostat from honeywell RTH6580WF1001 that I like and would love to be able to use is for both heating and cooling. Any help is appreciated. Thanks!
Old 02-27-15, 07:44 AM
Yes very doable. You will need to do some wiring on the boiler.
Old 02-27-15, 10:30 AM
W
Can you be more specefic?
What wiring would need to happen on the boiler?
Old 02-27-15, 11:53 AM
First you need to find out how many wires you have at the cooling stat.
