Moaning sound from plumbing after flushing toilet....
diyer1's Avatar
TX
10-27-14, 12:55 PM   #1 (permalink)
Hello all,
A while back our main drainage line was stopped up, so we had to have someone come out and snake the line from the outside. They fixed that problem but ever since, the plumbing has made some loud moaning sounds whenever the downstairs toilet is flushed. It can be heard from the upstairs bedrooms also. It's the loudest in the wall right behind the downstairs toilet and runs up the walls. It only lasts for a few seconds and then stops. I'm not sure where to start, so I'm hoping to get some advice here. Thanks in advance for your help!
Tags: toilet, plumbing, pipes, noise, sounds, moaning
Furd's Avatar
WA
10-27-14, 01:21 PM   #2 (permalink)
Moaning is rarely a problem with the drainage or venting system but it is often a problem with the supply piping when the toilet refills.
Try this, take off the tank cover and while holding the float up (so the tank won't refill) flush the toilet. Does it still moan? Release the float and see if it moans while refilling.
Post back.
guy48065's Avatar
MI
10-28-14, 03:54 AM   #3 (permalink)
Did the plumber arrive with a helper...but leave alone?
Sounds like the start of a good book...
diyer1's Avatar
TX
10-28-14, 06:19 AM   #4 (permalink)
Thanks for your reply Furd. I took your advice and the sound is coming from the refill valve. I'll replace it here pretty soon. Thanks for your help!
Furd's Avatar
WA
10-28-14, 12:24 PM   #5 (permalink)
Don't get too excited about changing the fill valve just yet. It could be a loose washer in the shut-off valve under the toilet or it could be just a piece of dirt in the "guts" of the fill valve itself. Many of the newer fill valves can be easily disassembled to flush out any dirt. A picture of what you have might help.
diyer1's Avatar
TX
10-31-14, 02:16 PM   #6 (permalink)
I haven't been back on here since the last time I posted, so I didn't see your latest post until today. I did end up changing the fill valve and that was in fact the problem. No extra noises when flushing now. I had no problem updating the valve anyways...it was the old floating ball type.
