Floating vinyl planks moisture barrier and/or underlayment?
denn30's Avatar
WA
03-12-17, 11:11 PM   #1 (permalink)
hi there,
been goggling the subject for a couple of hours now and getting a little confused. i have 3 projects that i need done. 2 are floating vinyl planks and 1 is floating laminate plank (i'll ask in the other forum).
1st project:
i want to install luxury vinyl plank flooring, floating, in the 2nd floor bathroom. the subfloor is 3/4 inch plywood over joists. there will be 1/4 inch plywood attached to the original 3/4" plywood.
do i need a moisture barrier? do i need an underlayment?
2nd project:
i want to install luxury vinyl plank flooring, floating, for the kitchen floor, similar situation to the bathroom. 3/4 inch plywood over joists. 1/2 inch plywood over the 3/4 inch plywood (previous owner had vinyl sheets glued down).
3rd project: i'll post in the other forum as well.
i want to install, laminate plank flooring in the living room, floating, thin pad already attached. over 3/4 inch plywood subfloor over joists.
do i need a moisture barrier? from what i've read, i should NOT use a moisture barrier as it may lock in moisture in the plywood subfloor.
thanks in advance!
dennis
chandler's Avatar
GA
03-13-17, 03:20 AM   #2 (permalink)
No on all three counts. This is a duplicate of Moisture barrier needed??
We try to keep all the threads of one subject together, so one may be deleted or merged.
stickshift's Avatar
WI
03-13-17, 08:22 AM   #3 (permalink)
I deleted the other thread since all of the questions were answered here.
joecaption's Avatar
VA
03-13-17, 08:24 AM   #4 (permalink)
Not sure why your doing all that searching, just read the install directions right on the box or on the manufactures website.
Follow to a tee or there's no warranty.
denn30's Avatar
WA
03-13-17, 10:48 AM   #5 (permalink)
thanks for the responses. and thanks for merging my thread into one.
one more question: for the kitchen and bathroom with floating vinyl planks, will i be doing any harm if i added an underlayment for sound and warmth?
thanks again!
stickshift's Avatar
WI
03-13-17, 11:05 AM   #6 (permalink)
Vinyl generally gets installed on 1/4" plywood underlayment. Again, please read and follow the actual directions from the manufacturer.
denn30's Avatar
WA
03-13-17, 11:25 AM   #7 (permalink)
thanks for the reply. thanks!
