room transition recommendations
lapubell's Avatar
OR
04-29-17, 08:21 PM   #1 (permalink)
hello. my wife and I just bought our first home and have been making great progress on some renovations. We found out that some of the old linoleum was asbestos based, so we decided to contain it rather than rip it up. so, we now have some new flooring glued down, and it's quite nice.
now we have about a quarter of an inch of 4 layers of glued vinyl flooring that is offset from the hardwoods. we are looking to install some sort of transition strip, but the basic ones that you screw down have exposed screw heads, which my wife pointed out can catch on tights, or socks. The other common strips that I see available are for the opposite scenario, where some installed laminate flooring is now taller than the other room's flooring.
I'm just looking to see what people recommend for our situation. thanks!
Marq1's Avatar
MI
04-29-17, 09:24 PM   #2 (permalink)
They do make many transitions that have a channel that is screwed down and the molding snaps in.
chandler's Avatar
GA
04-30-17, 04:16 AM   #3 (permalink)
Understanding all you have is linoleum on one side and hardwoods on the other?? The total offset is 1/4"? You would need a transition similar to what Marq1 illustrated, but in an offset. I ran across one that is screwed down with that offset, but the screws sit in a countersink that would alleviate the problem of snagging things. TrafficMASTER 2 in. x 3 ft. Oak Carpet Trim-18573 - The Home Depot
sam floor's Avatar
MO
05-01-17, 04:20 AM   #4 (permalink)
track moldings are made with several different sizes of offset.
Flooring Installer since 1973
lapubell's Avatar
OR
05-03-17, 05:34 AM   #5 (permalink)
thanks
that oak strip might be perfect.
thanks!
