Wallpapering over backing paper primed w/oil-based sealer?
jawarrior's Avatar
CT
08-12-17, 08:57 AM   #1 (permalink)
Is my plan sound?
My master bath is papered with a vinyl-coated wallpaper. The vinyl layer peels off very easily. Underneath is a firmly attached backing paper which is pasted onto a painted, sized Sheetrock wall.
I'm in my 60s and not as physical as I once was. To avoid the very time-consuming, extremely messy and physically-demanding task of wetting and scraping off all that backing paper, I've considered fixing any loose areas and seam areas with compound and then sealing everything with oil-based Kilz sealer - oil-based so it won't soak into and dissolve the old water-based adhesive behind the backing.
The backing paper is firmly in place. The bath has a ventilation fan. I want to cover the walls with a paintable, strippable textured wallpaper. The lower 4 ft. of the wall will be beadboard. No wallpaper will be around the sink or the tub/shower.
Anyone with experience know if this will last?
marksr's Avatar
TN
08-12-17, 09:10 AM   #2 (permalink)
Welcome to the forums!
Removing the wallpaper backer is best! Generally it comes off fairly easy when wet. I usually mist the wall with water from a pump up garden sprayer. Get it as wet as you can without making a mess [rags/towels at the floor] then scrape. That said, an oil base primer will generally seal the paper but you can still get bit by any paper with a poor bond to the wall.
Did I mention it's best to remove all the paper
retired painter/contractor avid DIYer
jawarrior's Avatar
CT
08-12-17, 10:43 AM   #3 (permalink)
Mark,
Is it true that vinegar in the water will aid in dissolving and loosening the old backer/adhesive?
marksr's Avatar
TN
08-12-17, 12:20 PM   #4 (permalink)
Some swear by it, others by adding fabric softener to the water. Personally I think as long as you get it wet - that's all it needs. The wallpaper paste is water soluble, once you get water/moisture thru the paper - it will dissolve the paste.
Marq1's Avatar
MI
08-12-17, 03:29 PM   #5 (permalink)
get it off, it has the potential to come back and haunt you regardless of how solid it appears. Nothing worst than having to re-do a project due to a ill advised short cut>
jawarrior's Avatar
CT
08-18-17, 01:23 AM   #6 (permalink)
Thanks all for the advice.
