Does this look like a load-bearing structure?
Hello everyone,
I was curious, does this look like it could be a load-bearing structure? This is in our kitchen. Old 1920's row home in Philadelphia.
I looked and our neighbor's house does not have this in their kitchen and she said they never had a small breakfast nook. Just curious as I want to take it down to maximize space.
Thanks.
Thanks.
You're asking about the arch with the spindles ?
That doesn't look like it's load bearing.... especially if the wall to the right is an outside wall.
I see what looks like a beam over the left side opening of the picture by the door... what is that ?
Not over the door.... across the top of the picture.
Correct, outside walls on each side.
The beam looks like it was something the previous owners had to hold something like pots/pans or maybe they had a light strip or something on it.
The beam is not continuous. In fact, it only goes from the outer wall to about 4.5 feet to the center, then the arches take over for the breakfast nook.
Thanks.
Thanks.
With both walls being outside walls it would be highly unlikely that that is a load bearing wall.
The only thing that might change this is if that nook is a bump out and was added at a later time after the house was built.
Thanks.
Well, I was wrong about the beam going across the entire span of the kitchen as it was, but you all were correct, it was not a load bearing wall.
It looks like they nailed a 2x3 to the joist and just went the entire width of the joist to connect the 4x4 to that created the wall separation for the breakfast nook and stove. The adjacent vertical 2x3 is not under the joist span 2x3, so it's confirmed.
I confidently cut through the 4x4. I'm about 50-60% done the demo and cleanup, then I can begin the fun work of putting everything back together and hanging the new cabinets.
A lot of work!
Thanks.
A lot of work!
Thanks.
Looks like a sewer line hanging out there in the wall.
Those are two hot water radiator pipes that I am in the works to relocate a few inches back.
I have a long thread in the plumbing/piping section with my random thoughts on how to fix it.
Thanks.
