What tools would I need to cut a circle in my pc case?
Ozpium's Avatar
TX
04-22-17, 03:26 AM   #1 (permalink)
I want to cut a window hole (apx. 8" DIA) in a PC case panel. The panel is probably about 1mm thick with some thin sound dampening material on it (like rubber as thick as a pencil lead)
What would I need to cut a hole in it that's as close to perfect as possible?
marksr's Avatar
TN
04-22-17, 03:34 AM   #2 (permalink)
Welcome to the forums!
How perfect does it need to be? A hole saw will cut a nice circle but at 8" would be pricey. I'd consider drilling a hole and then cutting it out with a jigsaw. The edges could be dressed up by sanding.
retired painter/contractor avid DIYer
pugsl's Avatar
NC
04-22-17, 03:46 AM   #3 (permalink)
Here is a page of hole saws, there is a 200 mm one for 41$ 7 7/8 and a 8 inch for 90* $ , Might be cheaper to take panel to machine shop to have hole cut.
https://www.amazon.com/s/?ie=UTF8&ke...l_3w7aa6sok4_e
Ozpium's Avatar
TX
04-22-17, 03:54 AM   #4 (permalink)
Jigsaw
Wouldn't a jigsaw just go everywhere? What's a machine shop? I saw someone suggest that for another PC mod but I don't know what a machine shop, no hits for that in Dallas at least.
The cheapest I can get someone to do it for is $50 dollars and even then I'm not sure they'll do a good job of it, so if it's not that much more it seems a better idea to get the tools in case I mod someone else case the same way.
Also it's steel. Forgot to mention that.
chandler's Avatar
GA
04-22-17, 04:33 AM   #5 (permalink)
You know you have piqued our curiosity. What would be the purpose of an 8" hole in a PC case? And how many people do you have standing line to have this modification done??
marksr's Avatar
TN
04-22-17, 04:55 AM   #6 (permalink)
It shouldn't although you do need to use care and pay attention. You'd want a metal cutting blade. You'd then clean it up with a drill operated drum sander.
It's mostly for automotive work but they have an assortment of metal working tools. I'd expect the Dallas area to have a dozen or more machine shops. Look in the yellow pages or ask at your local automotive parts store.
pugsl's Avatar
NC
04-22-17, 05:09 AM   #7 (permalink)
Here is a page of machine shops in Dallas, Don't know where youare so the list.
https://www.google.com/search?q=Dall...utf-8&oe=utf-8
Yes you could use jigsaw but hole would not be pretty. Unless you have years of practice. I have used them for 40 + years and still can not make a nice round hole.
Tolyn Ironhand's Avatar
MN
04-22-17, 05:19 AM   #8 (permalink)
A circle cutter that is designed to cut through sheet metal for duct work would likely work. You drill a small hole in the center of where you want the hold cut and then insert the center. Google "sheet metal hole cutter"
You may also be able to rent one or rent a large hole saw.
Electrical AC/DC and lighting Moderator
Professional Electrician, Handyman, all around swell guy!
40,000 people die in auto accidents per year in the US. We should ban cars.
