Rust, greater in water or air
Marq1's Avatar
MI
04-02-17, 01:34 PM   #1 (permalink)
My whole life has been the elimination of rust, now I'm looking for the fastest way to get it.
Just welded up a "VW" sign and want to get it into a rusty patina look.
Do I just set it outside or tie a rope on it and drop it in the creek??
Vermont's Avatar
VT
04-02-17, 01:49 PM   #2 (permalink)
I think you wash it with soap to remove any grease and then periodically coat it with vinegar ?
NJ
04-02-17, 02:02 PM   #3 (permalink)
In order for it to rust faster in water you would need to replace the oxygen that is getting depleted during the rusting process. That means it would rust faster in the open air and being kept wet.
~ Pete ~
Gunguy45's Avatar
Super Moderator
AZ
04-02-17, 02:17 PM   #4 (permalink)
I agree, in the air with frequent wetting will probably do the best.
Vic
"I sometimes wonder how some people ever made it to adulthood..."
Marq1's Avatar
MI
04-02-17, 10:43 PM   #5 (permalink)
Maybe I'll bury it in the pile of wet wood chips in the backyard for a couple of weeks and see what that does??
ray2047's Avatar
TX
04-02-17, 11:01 PM   #6 (permalink)
Basicly salt, hydrogen peroxide, and vinegar. How to Make Metal Rust in Less than 10 Minutes | MountainModernLife
I can explain it to you, but I can't understand it for you.
Gunguy45's Avatar
Super Moderator
AZ
04-02-17, 11:03 PM   #7 (permalink)
All depends on what it's made from I guess, but most regular steel will flash rust overnight. If you want that good old junk car sitting in a field for 10 years look....well, leave it in a field for 10 years...lol.
Here's another couple of methods...3 Ways to Make Metal Rust - wikiHow
Vic
Hal_S's Avatar
PA
04-03-17, 05:45 AM   #8 (permalink)
Posted By: Marq1 Do I just set it outside or tie a rope on it and drop it in the creek??
Depends on the creek.
In the Pennsylvania coal regions, auto shops would strip the rust off exhaust headers
by soaking them in the creek overnight (per Dept. Enviro. Protection friend who works on water quality issues).
Acid mine drainage in Pa & West Virginia can drop the water's pH to 3.5 (or lower)
that's in the range of acidity normally found in industrial acids.
