10 Advantages to Using a Carport 10 Advantages to Using a Carport
A carport provides shelter for your vehicle. People and pets aren't the only things that need shelter from the elements. Besides a home, an automobile is usually considered to be one of the more important investments you make. A carport is a shelter constructed from wood, metals or other materials. It tends to take the place of a garage. Here are 10 advantages to using a carport.
Advantage #1: Weather Safety
A carport can keep your car far away from the elements, whether harmful summer rays, winter snow, sleet or rain. A carport usually has a roof and sometimes sides. However, it is not usually enclosed.
Advantage #2: Helpfulness for Singles
A carport can be helpful for people who live alone. Carports usually sit close to the home. Therefore, pulling up and into a carport and parking closer to the front door could be safer than parking in the street.
Advantage #3: Protection against Burglars
Speaking of safety, housing a car under the carport may also shield it from vandalism or other random attacks. Burglars or perpetrators may be less inclined to enter a carport close to the home.
Advantage #4: Additional Space
You can use carports as outdoor porches if you need extra space.
Advantage #5: Other Vehicle Storage
You can also use a carport as a home to boats, trailers, snowmobiles, ATVs, motorcycles and other methods of transportation if you don't have room in your garage.
Advantage #6: Shade
You may use a carport as a play area for children or shaded areas for adults.
Advantage #7:  Organization
If you install a carport with walls, it may also serve as an extra storage unit for tools, boxes and other items.
Advantage #8: Convenience
Because most carports are open areas, they do not have doors. Ultimately, the lack of door can be more convenient when you come home with grocery bags or other items you need to carry inside. A carport can also save on energy and electricity.
Advantage #9: Added Home Value
If your home does not have a garage and you decide to sell it, buyers might consider it a disadvantage. At least with a carport, prospective home hunters will see they can park their car, motorcycle or boat on the grounds rather than the street.
Advantage #10: No More Storage Units
A carport could save from having to rent a storage unit.
Most of the time, you can construct a carport to resemble or at least blend with the architecture of your home, be it bricks, siding or wood. Before you decide to purchase a pre-fabricated carport, construct a carport on your own or even call in a professional, check with your city or homeowners association for zoning ordinances or for what is allowed in the neighborhood. Some communities require permits and proof of plans.
