Login Error
Close
10 Basic Table Saw Safety Tips
by DoItYourself Staff
Table saw safety is very important. While a table saw is a very useful tool that can be used for a wide variety of projects, it can also be very dangerous if used incorrectly. The following list should help you stay safe when using your table saw.
Follow Instructions
You should familiarize yourself with all safety procedures associated with your table saw and its accessories. Your owner's manual will be very helpful to you here. Read it carefully and take note of any advice it gives you on how to use your table saw's safety features most effectively. This is only useful advice if you follow the instructions you read, so be careful.
Keep Your Work Area Clean
While this might not seem very important, in reality a dirty work area can be dangerous. Keeping the floor clean in particular can keep you from slipping and falling on your table saw.
 Keep your table saw's work surface clean. Polish it so it is not rough. A rough tabletop can lead to many problems. A smoother tabletop allows you to use less force when cutting, which is much safer and makes it much easier to avoid kickback.
Push Stick
Sometimes, you will use your table saw to cut stock that is less than 6 inches long. When you do this, use a push stick to keep your hands clear of the table saw's blade.
Dress Properly
When using your table saw, what you can help keep you safe. First, it is important to avoid wearing any loose clothing. All of your clothes should be tight fitting, and things like ties or jewelry should be left off. Additionally, you should wear proper ear and eye protection while operating a table saw.
Adjusting
Sometimes, you will have to make adjustments to your table saw or its safety features. While this is fine, you can avoid a lot of trouble by making sure that your saw blade has come to a complete stop first. Additionally, unplug your table saw before making any changes.
Never move any part of your body past or over the blade until it has come to a complete stop. Doing this is an unnecessary risk.
Maintenance
Maintaining your equipment properly is essential. Use a blade that is both sharp and clean. Dull blades can lead to kickback and other accidents. Doing this allows you to use less force when cutting, which drastically reduces the chance of kickback.
Stock
Certain types of wood can cause problems on a table saw, so it is important that you carefully examine everything that you cut before actually cutting it. Look in particular for foreign objects such as old nails or screws. However, knots in the wood are also an important thing to look for. Foreign objects can cause kickback, damage your saw blade, or become high speed projectiles. Naturally, it is best to avoid a problem like this completely before it happens.
 forum activity
