Login Error
Close
10 Common Vinyl Siding Problems
by DoItYourself Staff
Vinyl siding problems have become nightmares for an increasing number of homeowners. Though this siding material is very popular, it is important for buyers to be aware of the drawbacks and environmental dangers it poses. Many people think that vinyl siding is a one-time, maintenance-free installation. However, as time goes by, they prove to be wrong. Below are some of the most common drawbacks of vinyl siding.
1 – Unappealing in Comparison to Wood or Stone
Vinyl siding is available in many colors and textures. It can simulate the look of wood very closely. However, a discerning eye can quickly make out the difference between authentic and fake wood. No matter how well it is made and installed, vinyl siding can never be as authentic as wood or stone.
2 – Releases Toxins at High Temperatures
Vinyl siding is a product that is under constant criticism from environmental organizations. It is a plastic material that is manufactured in an environmentally hazardous manner. The end product is also toxic at high temperatures. If it catches fire, it can expose people indoors to high amounts of toxins.
3 – Fades after Few Years
Vinyl siding is available in many different price ranges and qualities. The cheapest ones are most susceptible to fading and discoloration. After a few years, you will find that the siding has lost its appeal and you may have to replace it.
4 – Can Crack or Bend under Pressure
Vinyl siding can be damaged when hit by objects or if you accidentally push the snow-blower or lawn mower against it. Cracks and other forms of damage cannot be repaired easily. You may have to replace the damaged part of the siding, which can be complicated because it is difficult to find exact matches.
5 – Requires Regular Cleaning
Vinyl siding will accumulate dust, mold and mildew after some time outside. If left unattended, these problems can invade your home. Annual cleaning of vinyl siding is a requirement, contrary to popular conception that it is maintenance-free.
6 – Can Hide Moisture Problems
Vinyl siding can be susceptible to moisture problems if you use pressure washers or clean the siding improperly. Moisture underneath the siding can quickly invade your home and lead to mold, cracking paint and damaged wallpaper.
7 – Inadequate Insulation
Vinyl siding does not offer good insulation. Newer varieties of the siding material come installed with foam, which offers better insulation. However, most vinyl sidings require additional backup when it comes to insulation.
8 – Insufficient Color Choices
Vinyl siding can crack and bend out of shape if it is exposed to high temperatures. Because dark colors absorb more heat, vinyl sidings are usually found only in lighter shades.
9 – Lowers Property Value
Vinyl siding does not enhance property value, unlike wood, stucco or stone. It can be unattractive to many buyers, especially in upscale neighborhoods.
10 – Bad Choices for Historic Homes
Vinyl siding can damage the charm and original appeal of historic homes. The installation process may require changes and can even damage the underlying structure.
 forum activity
