Login Error
Close
10 Muriatic Acid Safety Tips
by DoItYourself Staff
Muriatic acid is commonly known as hydrochloric acid and is commonly used in cleaning, manufacturing and rust removal applications. It is mostly used in industrial settings, but some homeowners also use it for cleaning applications around the house. Muriatic acid is highly corrosive and can cause severe problems if it comes in contact with skin or is inhaled. It is very important to take adequate precautions and wear protective equipment when you handle muriatic acid.
Tip 1: Wear Chemical Resistant Clothing
Muriatic acid is highly corrosive and can react chemically with normal clothing, resulting in damage to the clothing and also your skin. To prevent this, you must wear special chemical resistant clothing made of Polyvinyl Chloride (PVC) or butyl rubber.
Tip 2: Wear Safety Mask
The fumes of muriatic acid are dangerous. If you inhale these fumes, you may end up damaging your respiratory tract and organ linings. Always wear a safety mask over your face when you work with muriatic acid. In addition to preventing fume inhalation, a safety mask will also protect you from unexpected reactions with other materials.
Tip 3: Work in a Ventilated Place
Always work in a place that has plenty of ventilation. This will prevent fume buildup and reduce the amount of toxins you assimilate.
Tip 4: Use Gloves
Always wear thick gloves made of butyl rubber, PVC or neoprene. Use shoes made of the same materials. In case of spills or chemical reactions, these materials will resist damage from the muriatic acid. Also ensure that your pants are over the shoes, so that there is no skin left exposed.
Tip 5: Do Not Mix with Other Chemicals or Liquids
Muriatic acid may react explosively with other chemicals and liquids such as water. Such reactions may produce toxic fumes, smoke and heat. Avoid mixing muriatic acid with other materials if you are unsure of the result.
Tip 6: Keep Away from Heat
To prevent explosive reactions, keep muriatic acid away from heat at all times. Never store is close to a source of heat.
Tip 7: Keep Away from Children
Young children and pets that come in contact with muriatic acid can be severely injured. Accidental ingestion of muriatic acid can even lead to death. Contact with the eyes may cause blindness. Never leave muriatic acid lying around in an easily accessible place.
Tip 8: Get Prompt Medical Attention if Needed
If muriatic acid makes contact with the skin, eyes or is accidentally ingested, it can lead to serious problems. In such cases, contact a doctor immediately. The affected area must also be promptly washed with water. If a person has difficulty breathing after inhaling the fumes, he must be moved to the outdoors and given prompt medical attention.
Tip 9: Follow Safe Storage Measures
Store muriatic acid in a tight, securely closed container. Keep it in a locked location in a cool, dark area. Make sure the container is clearly labeled.
Tip 10: Dispose of Safely
Never pour muriatic acid down drains or into ponds or lakes. It can alter the pH of the water and harm aquatic life. It can also seriously corrode your plumbing. Muriatic acid is considered a hazardous material and must be disposed of in accordance with local regulations.
 forum activity
