Login Error
Close
10 Safety Tips when Using a Nail Gun
by DoItYourself Staff
A nail gun is an automatic tool that ejects nails onto construction materials with great force. If you are working on a large-scale remodeling or building project, a nail gun is a necessary tool. When you operate this type of dangerous tool, you must follow some important safety tips.
1 – Wear Safety Gear
When a nail strikes a surface, it can send splinters flying. You must wear a face mask and safety goggles to protect yourself. Protect your ears with a protective cover as well. Wear thick gloves and sturdy boots. Work in a clear, slip-proof, well-lit area.
2 – Familiarize Yourself with Your Tool
Nails guns are simple tools, but they must be handled with great care. Hundreds of workers are injured every year because of misfired nails. Only purchase a tool that meets required safety standards. Before you use your tool, read the instruction manual thoroughly and familiarize yourself with the safety features and basic parts of the tool. Never attempt to modify the tool in any way.
3 – Observe Your Surroundings
When you fire a nail gun on a construction material, the nail may sometimes break through that material and hit someone on the other end. Never fire a nail gun on a concealed surface without confirming that it is safe to do so. Let co-workers know when you are about to start.
4 – Hold the Nail Gun Properly
Never carry a nail gun against your body. An accidental trigger could send nails flying and cause serious injury. Be very careful to disconnect the nail gun and carry it away from your body when you climb ladders. Never touch the trigger when you carry the nail gun. Make sure it is switched off, unplugged and the safety catch is in place before you transport the tool.
5 – Never Point the Nail Gun at Anybody
Avoid conversations and other distractions when you are working with a nail gun. Never turn around when the tool is being operated. Keep your free hand well out of the line of fire.
6 – Unplug the Tool before Performing Maintenance
To perform any cleaning or routine maintenance, switch off and disconnect the nail gun first. Take it to a clear, uncluttered area where you have plenty of light. Use only clean nails free from rust.
7 – Never Use the Nail Gun around Combustibles
Using any power tool in the vicinity of combustible materials is very risky. The tool can give off sparks that could start a fire.
8 – Ensure that the Nailing Surface is Safe
Some nailing surfaces could be concealing electric lines or gas pipes. Before firing a nail gun at any surface, you must ensure that it is safe for you to do so.
9 – Move Carefully
If you are moving in a line as you are firing the nail gun, make it a point to start at an edge and then move inwards. This way, you can avoid falls.
Also, avoid walking backwards as you fire the nail gun. Start at the back and move forwards instead.
10 – Store the Tool Safely
Keep the nail gun away from people who are not trained to use it. store it safely in a dry area with your other tools.
 forum activity
