Login Error
Close
10 Tips to Keep Your Basement Dry
by DoItYourself Staff
To avoid structural damage and expensive repairs in your home, you must make efforts to keep your basement dry. A damp basement can also lead to several other problems such as mold, fungus and mildew, and can cause health issues such as asthma and allergies in the family members as well. Some of the below tips can help you in keeping your basement dry and warm.
1 – Ensure that Water Flows Away from the House
Sometimes the landscaping around the house is to be blamed for water accumulation around the foundation. Ensure that the ground slopes away from your home, and that water does not form puddles around the foundation.
2 – Install Gutters and Downspouts if Needed
If your home does not have an efficient system for collecting rain water and melted snow, you must look at installing new gutters and downspouts. Make sure the downspouts are at least 5 to 6 feet away from the building structure and that water is directed a safe distance away from the house.
3 – Use Water Resistant Paint on the Walls
Moisture and condensation in basements sometimes causes the interior walls to “weep”. You can prevent this problem by using a high quality water resistant paint on the basement walls.
4 – Use a Dehumidifier
A dehumidifier is a valuable tool for absorbing excess moisture from your living space. Depending on the basement area, you may need multiple dehumidifiers to provide effective results.
5 – Put Rocks or Gravel around the Basement
Rocks or gravel absorb moisture easily and also dry faster. Putting some rocks around the periphery of the basement is an effective and cheap method of reducing moisture accumulation around the foundation of the house.
6 – Insulate Water Pipes
Cold water pipes may develop condensation on the surface due to moisture. Insulate the water pipes so that this problem can be avoided, and also ensure that there are no problems or leaks in the plumbing.
7 – Install Metal Window Wells for Basement Windows
Basement windows can collect water and retain it if not properly constructed. Metal window wells covered with pebbles or gravel can effectively prevent water retention and seepage through window frames to the basement walls.
8 – Avoid Drying Clothes in Basement
If you have excess area in the basement, avoid using it to dry clothes, as this contributes to the humidity and moisture in the surroundings. Use the dryer or dry clothes outdoors on sunny days.
9 – Ensure that All Appliances Vent Outdoors
Most people have their laundry rooms in the basement. Ensure that the washer and dryer are properly connected, and that the dryer vents air outdoors. Also ensure that there are no leaks from the washer.
10 – Install Exhaust Fans in Basement Bathrooms
Bathrooms and showers in basements are major contributors to humidity levels. Use exhaust fans where necessary to remove moisture and to improve ventilation. On warm, sunny days, leave basement windows open for some time. Avoid opening windows on rainy or humid days.
 forum activity
