11 Essential Gadgets in Auto Tool Kits
An auto tool kit can provide you with a great assortment of vital tools for your auto repairs. Here are a few to make sure your kit comes with.
Basics
Auto tool kits should have all the basics, like wrenches, screws, pliers, extra fuses and oil.
Safety Equipment
It’s vital that you have safety equipment in your tool kit. You’ll want to make sure you have a fully stocked first aid kit and a flash light.
Fuel Injector Testers
This may not be as cheap as some of the basic tools, but they can be useful. You can use them as a great diagnostic tool. You can find kits available at any auto part supply store.
Hydraulic Jack
If you want easy access to the undercarriage of your car, this is essential. Whether your task is replacing a simple flat tire, or you have a major undervaluing, a hydraulic jack will make your life much easier.
Suction Cups
During car repair you may be surprised at how much you can use these small inexpensive cups to help a repair job go faster. A suction cup can be used to keep a window up while working, or to hold a small tool on to a door. These are easy to store and are handy to keep around.
Battery Terminal Cables
Having a set or two of terminal cables on hand is essential. They aren’t expensive and store easily in any toolbox or bag.
Brake Bleeders
The braking system is one of the most important systems in a car. Since brakes are different in all models of cars you want to make sure your bleeders are the right size for the model you have. These can make a brake job much easier and faster.
Battery Chargers
It’s good to have a battery charger on hand for just in case scenarios.
Voltage Meters
It’s a good idea to have a meter in your auto tool kit. This can help you to determine the cause of any shorts you are experiencing.
Owners Manuals and Repair Guides
When all else fails, turning to a repair guide or the owners manual can certainly help a lot. Having these on hand doesn’t make you a lesser mechanic, it makes you a smarter one.
