Login Error
Close
12 Best Uses for a Rust Remover
by DoItYourself Staff
A rust remover is a chemical that is available in liquid, powder and gel forms. It provides a convenient method of rust removal in only a fraction of the time and effort one would otherwise need. Rust removers are widely used in residential and commercial setups. Below are some of the common uses for a rust remover such as Evapo-Rust®.
1 – Concrete Driveways
Concrete driveways and sidewalks often show signs of rusting. The cause is usually battery leaks from vehicles or fertilizer that is used for lawns and plants. These rust stains can effectively be removed with a rust remover made specifically for use on concrete. Rust remover in a powdered form can be mixed with water to form a paste that can be easily applied.
2 – Hand Tools
Hands tools used by mechanics, technicians or gardeners show signs of rust after a few months of use. There are rust removal solutions that can be used for the removal of these marks. Application usually involves immersing the rusted parts in the rust remover liquid for a few minutes.
3 – Engine Parts
Engine parts may show signs of rust, especially for older vehicles or antique, classic cars. In such cases, the use of a rust remover can effectively lengthen the life of the engine and improve the functionality of the vehicle.
4 – Nuts and Bolts
Nuts and bolts that are rusted can be easily cleaned by immersing them in rust remover solution. Follow up with a rinse and repeat the process if necessary.
5 – Antique Guns
Guns and firearms frequently need treatment for rust removal. Most gun training schools use commercial rust removers for this purpose.
6 – Classic Cars
Rust removers are favorites with people who like to restore classic cars. You can remove rust from the body before refinishing the surface. You can also remove rust from the different parts of the vehicle.
7 – Wheel Rims
Wheel rims of vehicles are affected by rust due to the intense level of usage. To remove the rust, you can treat the wheel rims of cycles or cars with a rust remover.
8 – Sidings
Sidings can sometimes show signs of rust due to constant exposure to the elements or because of leaking pipes in the vicinity. A rust remover can effectively tackle this problem.
9 – Steel Appliances
Steel appliances such as dishwashers or refrigerators can begin to rust after a few years of use. Apply a rust remover after testing it on an inconspicuous area.
10 – Iron Surfaces
Iron utensils, gates or fences may need frequent rust removal treatments. Spray on rust removers may be the most convenient for such applications.
11 – Patio Furniture
Patio furniture, especially those made of metal will show signs of rust and discoloration after some time. Applying a rust remover and then rinsing it off will make the furniture look like new.
12 – Bathroom Fixtures
Bathroom fixtures such as pipes, faucets, and showers may develop rust due to hard water. Application of rust remover is a convenient and easy way of getting rid of the rust. The same is true for toilet bowls that show discoloration and rusting.
 forum activity
