12 Paint Thinner Safety Tips
Paint thinner is a type of liquid that is used to thin oil-based paint and also to clean excess paint from work surfaces or application tools. There are many different types of paint thinner available, all of which have varying degrees of toxicity. On the whole, most paint thinners are dangerously toxic if not used and disposed of in the right manner. Below are some useful safety tips you can follow when you are working with paint thinner.
Tip 1: Work in a Well Ventilated Environment
Paint thinners emit fumes, which can cause nausea, headache or breathing trouble, among several other health problems. When you work with paint thinners, you must ensure adequate ventilation in the work area. Leave windows or doors open for proper air circulation. If this is not possible, make use of exhaust fans.
Tip 2: Wear Safety Equipment
Wear safety goggles, solvent resistant gloves and shoes when you are working with paint thinners. These articles will protect your eyes from possible splashes or fumes and also protect your skin from contact with the paint thinner.
Tip 3: Take Prompt Steps for Required First Aid
If you or any co-worker experiences breathing trouble, skin problems or has accidental contact with thinner on the eyes or other sensitive organs, you must arrange for immediate medical attention. Wash away paint thinner with water and soap.
Tip 4: Keep Paint Thinner Away from Acidic Materials
Paint thinner can react with acids and acidic materials in a hazardous chemical reaction. You must keep the two separate at all times.
Tip 5: Avoid Mixing Paint Thinner with Substances other than Paint
Never mix paint thinner with other substances, whether solid or liquid. It may result in explosive chemical reactions.
Tip 6: Keep Away from Explosive and Combustible Materials
Paint thinner is a volatile substance that must be kept away from combustible materials, liquids, heaters and open flames.
Tip 7: Never Consume Food in the Vicinity
Never eat or drink in the work area when you are handling paint thinners. The food substances can easily be contaminated and you may unknowingly ingest paint thinner.
Tip 8: Never Use Paint Thinner as a Generic Cleaner
Never use paint thinner to clean countertops, floors or walls. In addition to the risk of fire, you will also be exposed to the fumes indoors for extended periods of time.
Tip 9: Wash Your Hands after Use
After using paint thinner, you must wash your hands thoroughly with soap and water. This will keep your skin clear of the thinner and also reduce chances of skin inflammation or irritation.
Tip 10: Never Smoke in the Vicinity
Smoking in the presence of paint thinners is very dangerous. If an open flame lands on the thinner, it could result in uncontrollable flames.
Tip 11: Dispose of Unused Paint Thinner Properly
Paint thinner is a hazardous waste, which must be disposed of in keeping with the rules and regulations. Never throw paint thinner in regular trash or pour it down drains.
Tip 12: Keep Containers Tightly Closed and Safely Stored
Keep paint thinner containers tightly closed to prevent spillage. Store it in a safe place that is inaccessible to unauthorized people.
