15 Advantages of a Natural Gas Fireplace
When the cooler weather invades our lives, a natural gas fireplace can warm the soul as well as our homes. There is nothing nicer that curling up with a good book or the family pet in front of a glowing fireplace. And if you have a natural gas burning fireplace it is less costly to run, better for the environment and your home.
A natural fireplace has plenty of advantages that make it even more attractive to homeowners who are looking for not only style but also a savings on their energy bill.
Here are 15 advantages of a natural fireplace that may make your decision of choosing between gas and wood burning easier.
Number #1: Constant Heat
Unlike a log fireplace, a natural fireplace has constant heat supply.
Number #2: No Hauling
With a gas fireplace you will never have to buy or chop firewood or worry about harming a tree.
Number #3: No Sparks
Because there are no logs that mean no ashes or fly always that you have to clean.
Number #4: Energy Savings
A natural gas fireplace can save at least 25% on your energy bill
Number #5: Easy to Work
A gas fireplace can be turned on and off with the flip of a switch unlike a wood burning fireplace that can burn out without notice.
Number #6: Much Safer
The environment benefits nicely from a natural gas fireplace because there are no fumes or particles that are being released into the air or in your home.
Number #7: Stylish
There are numerous designs and styles in natural gas fireplaces that can add value to your home and look beautiful at the same time. From natural looking logs to beautiful grates, gas fireplace design has come a long way.
Number #8: No Chimney
A gas fireplace usually has a venting system which means they do not need a chimney.
Number #9: Warmer
There are gas fireplace models that have a blower already built in which helps to circulate the warm air throughout the home and not just in one area where the unit is places.
Number #10: Remote
There are manufacturers that produce natural gas fireplaces with a remote control similar to a TV remote making it easy to operate for anyone in the family.
Number #11: No Bans
There are States that have banned the use of wood burning fireplaces because of environmental concerns.
Number 12: Installation
The cost of installing a natural fireplace is often cheaper that a wood burning fireplace and can be easily installed by either a Do-It-Yourselfer or a professional.
Number #13: No Storage
Because a natural gas fireplace runs on gas, it is metered into the home by the local gas company. This is easier for the homeowner who doesn’t have to worry about storing natural gas at home or on the premises.
Number #14: Good for Kids
A natural fireplace is safer for children and pets since it is controlled and there are no fly away sparks or flames.
Number #15: No Creosote
Unlike a wood burning fireplace that needs to be cleaned along with the chimney die to a build-up of creosote, a natural fireplace does not.
