Login Error
Close
2 Advantages to Installing Radiant Barrier Foil Along Attic Baseboards
by DoItYourself Staff
If you have a large attic area, then you may be concerned about heat escaping through the attic, and wondering whether radiant barrier foil can help you to solve this problem. Attics tend to become very cold in the winter, and this can cause you a lot of problems with heating loss. Your whole home may become less warm due to heat passing through your attic baseboards. Adding a layer of radiant barrier foil can help you to prevent this problem.
1. Better Heat Reflection
Even if you have already used other types of radiant barriers, such as the barrier paint, fitting a radiant barrier foil layer can still help you to stop hot air rising through the attic. A radiant foil barrier is considered to block around 97 percent of all rising heat, meaning that it stops a much larger amount than other types of barriers.
2. Reduced Heat Transmission
As well as reducing the amount of heat put into the attic from other rooms, a radiant barrier foil also helps to reduce heating by limiting the amount of radiant heat produced on the side facing the attic. This helps to prevent heat from passing into the attic through transference.
 forum activity
