Login Error
Close
2 Best RV Roof Coatings For Cracks
by DoItYourself Staff
If you have suffered some cracking to your roof, then you will need to find suitable RV roof coatings to ensure that they are properly repaired. RV roofs are not like the roofs in permanent houses, and they need to be treated differently in order to get the most out of your repair. There are a number of different types of RV roof coating, and the type that you purchase will depend upon the different needs of your roof.
Rubber Roof Coating
This type of roof repair has the advantage of being sold in a liquid form. This allows you to apply a small amount of the substance directly around the area which has cracked. The small amount applied means that it will dry quickly, and you will be able to travel again as soon as the mold is set. This is the best form of roof repair if you discover a crack while you are travelling, and allows you to have a quick repair kit to hand.
Acrylic Roof Coating
If you notice the crack while you are at home, then you might try an acrylic RV roof coating. Acrylic is more brittle than rubber, and is not suitable for rapid applications, but it is also more solid than the rubber, and a firmer all-round roof repair.
 forum activity
