Login Error
Close
2 Mold Cleanup Solutions You Wouldn't Expect
by DoItYourself Staff
Mold cleanup is very important if you are concerned about your health or preserving investments such as your home, your water vehicles and many more. Mold grows in dark and moist areas and can cause respiratory problems such as asthma and allergies. It also slowly destroys your property if you do not clean them right away.
Although mold can cause a great deal of damage despite its miniscule size, mold can be easily cleaned with basic products you find in your home. Here are 2 mold cleanup solutions you wouldn’t expect.
Vinegar
Vinegar is readily available in any home and compared to other products in the market using a vinegar solution to clean mold is the safest and one of the most effective ways to clear mold on just about any surface. It also has no fumes that are harmful to your health. For bathroom molds, mix 3 parts of white distilled vinegar with 3 parts water. Use a sponge with the solution and soak the moldy area and let it set for a few minutes. Wipe down with a dry cloth after.
Chlorine Bleach
Chlorine bleach is also readily available in the home and can be used for mold cleanup. Every brand of bleach has its own mixture solution so follow instructions carefully. This works best for nonporous surfaces like counter tops and tiles. Place solution inside a spray bottle and spray on moldy surfaces. Let it soak for a few minutes and then wipe off until mold in completely gone. Make sure when cleaning the inside of the home that the area is well ventilated. Though bleach is a good mold cleanup solution, it can be very dangerous when inhaled. Also, if you are not sure about a surface’s reaction to bleach, first test a small, inconspicuous area or use the all natural vinegar-and-water solution.
 forum activity
