2 Off the Shelf Home Designs
There are at least 2 home designs that can purchased off the shelf. The off the shelf purchase are plans that are pre-made and standard and can be used in many communities. This means that the plans are designed to meet the building codes of the local community without much regard to design changes or modifications needed for approval.
The 2 off the shelf home designs that are discussed in this article include those for a ranch style home and a Cape Code style house. There are other off the shelf home designs that are available but the information that is provided in this article can pertain to other types of off the shelf home designs.
Ranch Style Off the Shelf Home Designs
Ranch style home designs that are off the shelf are a standard type of home design that can be found. Ranch style homes are single level house plans that feature several rooms, a living space, kitchen and bathrooms, all on the same level. The ranch style off the shelf home design is one that is easy to implement and build for a builder. Purchasing a ranch style home design can also be the least expensive of the ones that you find off the shelf. This is good for the home owner that is looking to save on some of the costs associated with purchasing their building plans and building the home.
Cape Cod Off the Shelf Home Designs
Cape cod homes are popular in the east coast of the United States. A cape cod home features several levels, a dormer roof that allows for expansion into an additional room for guests or a growing teen and many other elements that are simple and easy to design and implement.
Cape cod plans can be found online and made adaptable to many community’s building codes and standards. The use of cape cod plans can also be as inexpensive to build as those for ranch style homes. The material list that is included with a cape cod style home are not much different the material list that you will find for a ranch and other type of home plan that is purchased off the shelf.
Considerations for Off the Shelf Home Designs
When looking for off the shelf house plan designs, look for those hat are simple to implement and meet the relevant building standards for your community. The plans should incorporate all of the design elements that you are looking for in the type of home that you want to build and fit within the house building budget that you have set for the building of your new home.
Search the various sites and sources for off the shelf home designs to understand what is available and find the home design that meets your design and home needs. Taking the time to look through all of the home designs that are available will give you a wide breadth of choices to look at and choose from.
