2 Reasons to Build a Pole Garage 2 Reasons to Build a Pole Garage
There are a couple of great reasons why you should build a pole garage on your property. Here are some things to consider if you are still in the decision making process.
Reason 1 - Save Money
It isn't a surprise that often times using less material means spending less money. So when you are building a pole garage and use much less material than you do when you build a regular garage, you are going to be saving yourself a lot more money. You can also opt to have fabric or canvas or another type of cheaper fabric cover it or the sides that is less expensive then a garage would be, but also has the coverage that you may want or need.
Reason 2 - More Room
One of the reasons why a pole garage is so great is because you have an extra bit of room. Yes, you still have the covering that you want with a regular garage, however if you needed to fit more cars or tools in there, it is possible to easily expand it or just use more of the edge or perimeter. You are not restricted by walls when you are trying to move things in and out.
