2 Reasons to Install Interior Drain Tile With a Sand Basement
If you have a sand basement, you may want to consider installing an interior drain tile to improvement the structure and quality of the floor overall. Here are a couple of reasons why it is a good idea to make this change, to help you decide whether or not it is for you.
Reason 1 – Clogging Problems
The biggest problem there is with a sand basement is the clogging issue. This tends to happen when an excess of sand drops into the drainage. When you have a drain tile set up, you don’t have to worry about clogging the drains over and over. The drain clogging from sand can turn out to be very expensive as well as damaging to your basement over all.
Reason 2 – Visually Appealing
The other big reason why you should install drain tile in your basement is because it is more visually appealing overall. Even if you do not have a finished basement, a sleek and clean look and feel can help to contribute to the overall atmosphere of your home.
Both of these are solid reasons why you should consider installing drain tile in your basement. If you think it is right for you and your situation, contact your local hardware store for guidance.
