cancel
Job type :
Zip Code :
community forums
comments
2 Secrets to Cleaning Ceiling Lamp Glass
Everyone appreciates a ceiling lamp glass that is dust free. Below are two secrets to keeping your glass clean and particle free.
Option One - Wiping
Use a mild glass cleaner with a soft cloth and wipe gently. Be sure the light is turned off so you don't burn yourself. You should try to avoid using abrasive pads. Rinse the glass with warm water, and use a soft, dry cloth to dry the glass immediately after washing.
Option Two - Soaking
Take down any glass covers and soak them in a sink of warm soapy water to loosen the dirt, dust, and grime. Use a soft cloth to gently clean them. Rinse them well before drying to make sure there is no remaining residue.
Keeping your ceiling lamps clean will not only prevent fires, but also will create a pleasant environment for those around you, and alleviate symptoms for those allergic to dust. With these two secrets, cleaning is easy and hassle free.
member comments
Related Articles
How to Conserve Energy
Advice on saving energy in different seasons and climates... read more
3 Secrets To Cleaning Ceiling Lamp Glass
People often overlook cleaning ceiling lamp glass when doing their usual household chores... read more
Questions and Answers Archive
... read more
articles we like
Customize Your Window Treatments
Custom window treatments let you coordinate the style, pattern and color of your window treatments... read more
Compost Build
Generating a compost build has been done for many years, but it seems to be... read more
Where to Turn for Help if Your Company Doesn't Offer Tech SupportWhere to Turn for Help if Your Company Doesn't Offer Tech Support
Once a computer failure causes a slowdown so significant it costs the company money, any... read more
sponsored articles of the day
diy centers
