2 Tips for Testing an RV Propane System
Troubleshooting the propane system plays an important role in maintaining an RV. Thus, it is important to conduct rigorous tests on the propane system to ensure proper and full functioning.
3 Types of Tests
There are three tests that can be performed to check the regulator, which is the heart of an RV propane system. First of all. the regulator must be tested to ensure that the propane system will not be infiltrated by more than 14WCI: this test refers to the lock up test. The lock up test should be done every year to ensure safety. The second is a test on the operating pressure system, which regulates the pressure on the holder amidst the burning of several other propane appliances. Thirdly, a timed drop pressure test also checks whether there are leaks in the propane system.
Safety Measures
You should also check if the propane system uses safety measures. One of these safety measures is a flow-limiting device. This device is considered one of the most essential safety measures. It prevents gas from escaping the propane system if the system encounters excessive leaks. Propane systems should also use a black thermal-sensitive bushing to prevent fires and explosions.
