Login Error
Close
3 Tips to Using Wallpaper Wall Coverings
by DoItYourself Staff
Wallpaper wall coverings bring in a new dimension of style and beauty to your home. They not only accentuate the décor of your rooms, but also help maintain clean walls in your home. Here are a few tips you should consider while using wallpaper wall coverings.
1. Choose Your Wallpaper
It is important to understand what kind of wallpaper wall covering will suit your house best. You can use ordinary wallpaper, paper-backed vinyl or fabric-backed vinyl.  Paper wall covering is more artistic and appealing, while paper-backed vinyl is durable. Fabric-backed vinyl wallpaper is very easy to clean.
2. Take Measurements
Before using wallpaper wall coverings, be equipped with the exact measurements regarding how much of the wallpaper you will need. If you are not adept at taking measurements, seek assistance from a professional.
3. Proper Maintenance
It is important to clean your wallpaper wall covering on a regular basis. This keeps it firm and helps avoid the need for frequent replacement. Vacuuming, brushing, cleaning and mopping helps in keeping your wallpaper wall covering in good condition for a long period.
Wallpaper coverings add glamor and style to your home. Observing the aforementioned tips will keep your house looking fresh and relaxing.
 forum activity
