Login Error
Close
3 Advantages of Using a Wireless USB Hub
by DoItYourself Staff
You might not realize it, but a wireless USB hub can probably provide you with many advantages that you do not currently enjoy. Because they require a direct connection to your computer, standard USB hubs require special positioning that you may find inconvenient. Of course having no USB hub whatsoever is an even bigger limit, preventing you from using more external devices than you have USB ports on your computer. A wireless hub is the best solution for most setups. What follows should give you a good understanding of the advantages you are missing out on if you do not have a wireless USB hub.
Ease of Moving
Obviously it is easier to move a wireless USB hub from place to place than a USB hub that is physically connected to your computer. The advantages that come along with this, however, are not all quite so obvious.
For example if you have external devices that are difficult to connect to, particularly ones you do not need all the time, you may benefit from a wireless hub. With a wireless USB hub, you can easily disconnect it and move it to a place where you can conveniently connect to a device. This is particularly helpful for large devices, such as scanners and printers.
Less Mess
If you have ever used more than a few external devices with a computer, or had a network setup that involved more than two computers, you will know how difficult dealing with a mass of cables can be. Particularly if they are unlabeled, you do not want a tangled mess of cables behind your computer. If you find yourself in this situation, it can be tempting to ignore the pile of cables completely, but this leads to an entirely new problem. If you ignore your cables, eventually you will run out of ports and be unable to make any changes in your setup. As some of your external devices are probably not always useful, you may wish to avoid this situation.
A wireless USB hub can solve this problem. For one thing, it will reduce the number of physical connections between your computer and your external devices. Then the remaining connections in the back of your computer will be easier to manage and understand. For another thing, a wireless USB hub is easy to separate from the rest of your devices. You will more easily keep track of the devices connected to it.
Increased Range
Chances are good that you are limited by the length of at least one of your USB cables. If you use a normal USB hub that directly connects to your computer with a cable, you must keep your computer and all of your external devices in a fairly small space. This restriction can make your work space cluttered. However, if you use a wireless USB hub, you will enjoy a great deal more freedom in how you choose to place your various external devices.
 forum activity
