3 Advantages to Using Rubber Grommets in Plumbing Projects
If you are planning a plumbing project, then you may be looking into the idea of using rubber grommets. These are perfect for use with different types of pipes and plumbing fittings, and although they are not as hard-wearing as some other types of grommets, you will find that they are do have a number of advantages.
Not Corroded
The most significant advantage of rubber grommets over the older metal versions is that they are not corroded on contact with water. This can be a very significant change if you have hard or impure water, as this can damage most kinds of grommets. It also means that you will not have to worry about the parts rusting or becoming thin due to water damage.
Noise Reduction
The best place to use a rubber grommet is between a metal pipe and a wall connection. Pipes can vibrate quite a lot, and if you don't have the right kind of grommet in place, this can produce a disturbing noise every time you use the pipe. Rubber grommets reduce this noise by suppressing the vibration.
Cost
Rubber grommets are also available cheaply, which is a good reason to buy them. Not only are they inexpensive, but you should be able to find them in any local hardware store.
