3 Bathroom Cabinet Design Choices
If you are looking for a suitable bathroom cabinet design, then you may be overwhelmed by the range of choices that are on offer to you. You can install and fit any range of bathroom cabinets, but they should not be fitted until you have the the right design for the whole cabinet range. In order to work out what type of bathroom cabinet design you need, you should study as many as possible. If you are looking for the range of bathroom cabinet designs available, you should search online for as many different sources.
Prefabricated Designs
The most common kind of bathroom cabinet designs are those which are prefabricated, that is built to a manufacturer's design. If you have a basic bathroom design plan, then you can arrange your bathroom furniture to accommodate a sink, bathtub and toilet along with any cabinets that you choose.
There are so many different types of prefabricated bathroom designs that it would not be possible to describe them all. You can find ones which are designed to fit around the sink, or under the bath, others which are free-standing, and the basic medicine cabinet which screws into the wall. The latter are usually decorated on the outside with a mirror. If you are looking for basic designs, then the prefabricated model is the best variety. You can also find a range of less traditional designs, or those which fit in with historical themes, such as a Victorian bathroom, or a 1920s set.
Custom Designs
On the other side of the bathroom cabinet design range is the custom build. These are best used by people who already have the major elements of their bathroom installed, and want cabinets to go around, or if they have a very small area for a bathroom. If you are moving your bathroom, or reducing the amount of space it has to enlarge a bedroom, then you should consider prefabricated designs as the best option for installing them.
A custom design is quite often more expensive than the prefabricated, but you can have the cabinet designed and built to your own specifications, for example if you need a particular kind of wood used, or if you want a cabinet which is higher or lower than standard prefabricated models.
Making the Right Choice
If you are unsure what kind of bathroom cabinet design to choose, and are unsure of the cost of a custom, then you should consider looking at some of the in-between designs. Bespoke bathroom cabinets can be created at a furniture store, and computer technology will allow you to design and fit the designs according to your own needs. These bespoke bathroom cabinet designs means that you can choose the best out of the prefabricated designs, and although it may cost you slightly more than the standard cabinet which is built by yourself, it can also be adapted to fit a specific bathroom's needs, without costing as much as a custom design.
