Login Error
Close
3 Benefits of a Greenhouse Misting System
by DoItYourself Staff
A greenhouse misting system is important to help grow healthy and vibrant plants in your greenhouse. There are many benefits to having a misting system in your greenhouse.
Maintenance
A greenhouse misting system helps with greenhouse maintenance. Because greenhouse misting systems produce favorable and consistent conditions throughout the year, they are helpful for fending off plant diseases, minimizing plant stress, and increasing germination and growth rates.
Humidity
Anyone who has some experience with growing plants in a greenhouse knows how important it is to maintain consistent humidity levels. Often gardeners have to deal with low humidity and high temperatures. If the humidity is not controlled properly, plants can become damaged and even die. If the humidity drops below 30%, the plants can stop growing. A greenhouse misting system produces a high-pressure fog or mist that evaporates instantly to cool and humidify, without causing too much moisture to accumulate.
Temperature
Another advantage of a greenhouse misting system is that it reduces temperatures in a greenhouse by up to 30°F, in addition to keeping the humidity levels consistent. Because plant leaves absorb substances from the air and give off moisture, the best environment to encourage healthy growing plants is created with a misting system.
Fertilizer
Another benefit of a greenhouse misting system is that it can be used to apply fertilizers to the greenhouse more easily. The mist lands on the leaves of the plants, making the fertilizer easier to be absorbed. Misting systems for greenhouses make delivering fertilizer efficient and consistent.
If you are considering installing a misting system in your greenhouse, do research before making a final purchase decision. It's important to know what products are available on the market for greenhouses, especially as this is going to be a rather large expense. Once you install a misting system, however, it is worth the cost. Misting systems are designed to keep a greenhouse cool, moist, humid, and consistent at all times. These systems are the best way to create an environment for your greenhouse plants that is amenable to growth and cultivation.
If you don't know what type of misting system to install, consult a professional before making a purchase. This will ensure that you get exactly what you need for your size of greenhouse and the type of plants you want to grow.
It's a good idea to spend a little more money on a high quality system rather than buying a cheaply made misting system. It can be a hassle to have the system break down when you need it most.
 forum activity
