Login Error
Close
3 Benefits of Loose Fill Attic Insulation
by DoItYourself Staff
To prevent the loss of heat from your home, you may fit loose fill attic insulation to make your home more energy efficient. Understanding what benefits it can bring will help you to determine whether it is the best choice for you.
1 – Installation
One of the benefits of loose fill attic insulation is the ease of the installation process. There is no cutting or need for precise fitting required, which can make the process easier and quicker to complete. Loose insulation can simply be poured into place, which also makes it beneficial for awkward spaces.
2 – Quantity
The need to be precise with rolls of insulation will mean that you will need a large amount to ensure the project is completed properly. You will find that the quantity of loose fill attic insulation you need will be less than any other type of insulation. The thickness of the layer that you spread will also be a factor that determines how much you need.
3 – Renewal
When the need for renewing or removing loose fill attic insulation arises, you will find this easy to achieve. It is easy to add further loose insulation when it is needed and is easy to remove by sweeping it up.
 forum activity
