Login Error
Close
3 Ceiling Lamps That Save You Money
by DoItYourself Staff
When designing your home, you want to be sure that it is budget friendly and environmentally economical. One thing to assist you in making your home more economical is deciding which ceiling lamps to put in and where to put them. Here are three great options for ceiling lamps that save you money in the long run.
Energy Star Ceiling Fans
The first option to consider is installing an energy star qualified ceiling fan. There are a number of styles of this particular ceiling fixture that will fit just about any room. They circulate up to 15% more air than regular ceiling fans and are 60% more efficient than your average incandescent bulb. Be sure to look for the energy star seal when purchasing.
Mini Chandeliers
Another option is to consider mini chandeliers that can often be found on sale. Install one of these with a dimmer switch, and you have an easy way to not only alter the mood in any one room, but also save money by not using much energy. These types of ceiling lamps work well in just about any room , but especially well in a dining room, living room, and bedroom.
Recessed Ceiling Lighting
Finally, another great energy efficient option is to install recessed ceiling lighting. These can also be found with the energy star qualifications, and they have the ability to save up to 80% less electricity by using fluorescent lighting rather than incandescent bulbs. Be sure to use an airtight fixture when installing on the ceiling below an attic to prevent air loss. Newer airtight designs will prevent this loss. These are commonly used when installing under an unconditioned attic, but will also work for unheated basements.
These three options are not only all very stylish, but also energy efficient and affordable to install. By using any combination of these in your home, you will be certain to save money on energy costs in the long run.
 forum activity
