Login Error
Close
3 Common Mistakes when Removing Tile Adhesive
by DoItYourself Staff
Removing tile adhesive thoroughly is important before installing another type of floor. When performing this task, many people make mistakes that create more of a mess. Here are a few common mistakes that occur when removing tile adhesive.
1. Underestimating the Job
The most common mistake with removing tile adhesive is underestimating the job. Some people may think that this is going to be a simple job, and because of this, they think that they will be able to get it done quickly without any help. However, in most cases, taking up tile adhesive is going to be one of the most difficult jobs that you can do. Tile adhesive is a lot like concrete, and it is just as hard to chip up. If you are removing a large area of tile adhesive, you could potentially spend several days just on this one task. It is very difficult work, and you need to be able to handle a lot of physical labor in order to complete the job. Most of the time, you are going to want to have two or three people working on this task at once.
2. Not Having the Proper Tools
You could potentially remove the tile adhesive with a hammer and a chisel. However, this is going to be extremely hard, and it is going to take a long time to complete the job with these tools. When you are doing this type of job, you want to bring some more powerful tools with you. For example, you will want a small jackhammer that is designed to take up flooring. You might also want a power scraper. Renting the proper tools can go a long way towards helping you get the tile adhesive off your floor quicker and more efficiently. It might seem like an unnecessary expense to rent all of these tools. However, when you start doing the job, you are going to be grateful that you went to the trouble to get them.
3. Chipping Too Deep into the Subfloor
Another mistake that many people commonly make is that they chip too deep into the subfloor when they are stripping the adhesive. Since the tile adhesive is so similar to concrete, many people keep chiseling down into the concrete. This could potentially cause damage to the floor. When you are installing the new flooring afterwards, you may have to smooth it out with self-leveling compound. This is going to add extra expense and time to the job. If at all possible, you need to stop chiseling when you get to the bottom of the tile adhesive. You need to be very careful so that you can more easily determine the difference between the concrete and the tile adhesive. Otherwise, you could cause some serious damage to the floor and then spend hours trying to correct your mistakes.
 forum activity
