Login Error
Close
3 Countertop Options for an Outdoor Kitchen
by DoItYourself Staff
If you are making an outdoor kitchen, you are going to need to select some type of material for your countertops. There are a lot of different countertop material options that you can look at. Here are some of the different countertop options that you can use for an outdoor kitchen.
1. Granite
One of the most popular types of countertops in the world today is granite. This type of countertop surface provides you with a look that is unlike anything else out there. With granite, you are going to get a look with many different colors and variations contained within the countertop. This type of countertop surface is very shiny and it provides you with a very high-end look for your kitchen. When you utilize granite outside, you are going to want to make sure that it does not receive direct sunlight. Therefore, if you are going to use granite, you want to make sure that your outdoor kitchen has a canopy over the top of it. If granite is in direct sunlight the polyester resin that is in the granite can break down. This is going to give the granite a very weathered look in a short amount of time. Granite is also going to be on the high side of the price scale when you compare it to some of the other options that you have. Anytime that you purchase a product that comes in a full slab, you are going to have to pay a little more for it.
2. Concrete
Another very popular materials for outdoor countertops is concrete. Concrete allows you to create a number of different looks and textures. With concrete, you can utilize any color that you want through the use of dyes. They can also use decorative stamps in order to create a beautiful design in your concrete countertop. This allows you to customize the countertop a little bit and create any look that you want. Another great thing about using concrete countertops is that they are very durable. They are going to be able to stand up to any weather conditions that you might have and continue looking great. They are also not very susceptible to scratches or dents. This option is also going to be relatively inexpensive when compared to some of the other materials that you might look at.
3. Tile
You might also want to consider installing tile on your outdoor kitchen countertop. By doing this, you will be able to create a completely customized pattern or design. You can also use any color that you can possibly imagine with tile. Depending on what type of tile you use, you could choose an expensive one or a more economical tile. When choosing your tile, you want to make sure that you do not choose a basic ceramic as it can crack whenever the temperature gets below freezing. When you use tile for your countertop, you are going to have to make sure that you seal the grout so that it will not stain.
 forum activity
