3 Different Types of RCA Cables Explained
RCA cables are built to transmit different audio and video signals between multimedia devices such as camcorders to TVs or stereos to speakers. Other devices such as DVD, game console systems and cable receivers also make use of it. RCA Cable are wildly used everywhere by millions of people and has been a great help to the entertainment world. There are different types of RCA Cables, choosing what best suits your requirement will be your deciding factor for buying one
Single RCA Cable
This type of cable is used for single audio and video patching. A gold plated tip and protective jackets are its composition, and is build from nylon mesh.
Dual RCA Cable
This type of cable has an unbalanced pairs of either red and white/black or yellow and black connectors. Spiral braided wires and gold contact connector comprises the look of this cable.
Triple RCA Cable
This type of cable has more functions, it is used for single channel composite video and dual channel stereo audio thus maximizes its purpose. It is made up of PVC protective jackets and gold plated tips. All these types of cable have a length of about 3 to 50 feet.
When deciding what kind of cable to buy and make use of, you may consider thinking the purpose of why you need to buy it. For instance, if you are in need of a cable for your home entertainment system and would love to start watching high caliber videos in the comfort of your own home, you may opt to simply buy a single RCA Cable. Primarily, because it’s main function is just to patch a single audio and video device. Another reason could be that you need to have a connector or a cable for your stereo to have a great surround sound from your speaker.
These are basically some factors for buying a Single RCA Cable type. On the other hand, if you’ll need a cable not just for a single purpose, a Dual RCA Cable can best fit your requirement. A great example to this is a connection between TV and DVD and a microphone. Your Dual RCA Cable will connect the TV to the DVD for a great music video and your microphone onto the DVD as well for the sound output. Once connected, you may already start your way out to singing different songs. Same thing goes for the Triple RCA Cable. If you need not just one patching of cable such as dual channel stereo to be connected in a single channel composite, you may use the Triple RCA Cable.
There are countless ways for you to maximize your RCA Cable. Having one already signifies surefire entertainment anywhere in the world. It is definitely impossible for someone to experience it without having to use a cable or connector.
