3 Different Types of Vent Free Fireplaces Explained
Vent free fireplaces were invented so that homeowners can have a fireplace appearance in locations where an actual fireplace cannot be installed. Vent free fireplaces do not need a chimney and so it is an economical alternative to a conventional fireplace. A vent free fireplace is also considered a home design element utilized in several homes. And most of the time, they are utilized as secondary heat source.
Vent free fireplace are fueled by gel, natural gas or bottled gas. A number of states as well as local counties include ordinances and laws concerning these types of vent free fireplaces.
Vent free fireplaces need little fixing and do not employ the same British thermal unit (BTU) as a conventional fireplace. The gas burning form of the vent free fireplace while using less BTU's of fuel makes them an effective and economical choice for heating.
Take note that vent free fireplaces include three main types. The variation between every type is merely the fuel source. Every fuel type includes its own advantages and disadvantages, so you can just choose the type that suit your needs and lifestyles.
1. Vent Free Gas Fireplace
The first type of vent free fireplace utilizes propane or natural gas as its fuel source. You can obtain a variety of designs and styles, but compact units remain very costly. This unit type needs a link to a propane depot or natural gas line. You will observe that the vent free gas fireplace can be the best unit type if considering it as your secondary heating source. Nevertheless, it is the most expensive too.
Propane or natural gas vent free fireplaces can cause a host of safety problems such as carbon monoxide poisoning, physical sickness, and the potential for property damage. Ensure that your vent free gas fireplace is installed by professionals to lessen these risks.
2. Vent Free Gel Fireplace
Vent free gel fireplace also include wide selection of designs and styles. It is also requires the cheapest maintenance and fuel source budget. These fireplaces operate by means of a gel substance. This material is typically in a can and it can imitate wood burning smells and sounds. Take note that you can purchase wall hanging gel fireplace units, which best work as an additional décor for your home.
3. Vent Free Electric Fireplace
Vent free electric fireplaces do not create a real flame. Instead they utilizes electricity to create heat. Nevertheless, this type of fireplace does offer the visual appearance of a fire. Typically, they are mobile and compact. They are not as inexpensive as a vent free gel fireplace, but electric fireplacse are also less costly compared to vent free gas fireplace. This type of vent free fireplace is ideal for persons worried about open flames but wanting a secondary source of heat and the look of a fire.
