Login Error
Close
3 Easy Ways to Remove Wine a Stain from Silk
by DoItYourself Staff
what you'll need
  • Stain removal solution
  • Laundry detergent
  • Hydrogen peroxide
  • Liquid soap
  • Water
  • Cloths
When the need to remove a wine stain from silk arises, it must be undertaken as soon as possible. This makes it necessary to know which methods work best so that you can quickly put it into practice.
Step 1 – Laundry Detergent
Mixing a solution of laundry detergent and water that is stronger than you would normally use can be effective to help remove a wine stain. Use hot water and ensure the detergent is properly dissolved. Leave the silk to soak for a few minutes before gently rubbing it together at the point of the stain.
Step 2 – Liquid Soap
A liquid soap can be mixed with a small amount of hydrogen peroxide and applied directly to the silk to remove the wine stain. Use a soft clean cloth to work it into the fabric before dampening a cloth with water to remove it.
Step 3 –Stain Remover
Stain removing solutions are widely available with there often being specific varieties to remove any wine stain. Apply it to the silk in accordance with the instructions and do not leave it for longer than the allotted time.
 forum activity
