Having an attic fan is important to own or install as it keeps the whole house cool in warmer weather. Below are some great options to look into should you decide to install a fan for your attic.
Static Air Vents
The traditional static air vents are adequate, but may not provide enough air movement to make your house significantly cooler. While these fans may be less expensive, they may not provide the cooling needed for your home,
Solar Fans
Solar fans are a great option for those looking be "green", however you may need to install more than one to cool your home. The fans work best in areas with a good amount of heat and sun light. If you live in an area that cannot provide those two things, solar fans may not be a good option for your home.
Exhaust Fans
Exhaust fans are another good cooling option. These fans are designed to remove large volumes of hot air from the entire house while bringing in cooler air from outside. If you have a larger home, this may be the best option as it can efficiently recycle the air.
Questions of a Do It Yourself nature should be submitted to our
