Login Error
Close
3 Low Voltage Outdoor Lighting Bulbs Explained
by DoItYourself Staff
This article will discuss 3 low voltage outdoor lighting bulbs that are used by homeowners. These bulbs are idea for those individuals who are energy conscious and seek to be more environmentally aware by reducing their energy usage. Low voltage outdoor lighting bulbs can provide the same level of lighting and sense of security as high voltage outdoor lighting bulbs. Using low voltage outdoor lighting bulbs over comparable high voltage bulbs lowers an individual’s carbon footprint by reducing the amount of energy required for the lighting.
The 3 types of low voltage outdoor lighting bulbs that will be explained in this article include clear bulbs, flood lights and frosted bulbs.
1. Clear Outdoor Lighting Bulbs
Clear outdoor lighting bulbs are usually found in smaller lamps and lighting appliances outdoors that do not use a lot of energy. These bulbs are often limited for use in devices that use 12 volts or less.
Clear bulbs can have a traditional tungsten filament element that produces light when heated as the electricity in the light socket provides a charge. They can also be solar powered, using stored energy from the sun during the day in order to provide light by night, furthering its energy efficiency capabilities.
2. Flood Outdoor Lighting Bulbs
Outdoor lighting bulbs for flood lights that are low voltage are desired over those flood light bulbs that are high voltage. Low voltage flood lights can produce the same burst of light when an intruder or other person crosses the sensor beam so that safety is not compromised, which is the purpose for installing flood lights.
Flood lights that are voltage-based will use a combination of solar and traditional power to provide the lighting source necessary to work.
3. Frosted Outdoor Lighting Bulbs
Frosted light bulbs used in outdoor lighting that are low voltage add a decorative element to the home. They are found in accent lights and pathway lighting that lines a walkway leading to the front steps or garage. Some of these light bulbs can be solar powered, making them more energy efficient than comparable traditional low voltage outdoor lighting bulbs. Solar charged light bulbs store energy from the sun during the day and light themselves as soon as the sun goes down.
Discovering Different Light Bulb Options for Outdoor Lighting
There are other types of low voltage outdoor lighting bulbs that may be available for your lighting systems. Those described in this article are some of the examples of the types of lighting bulb options that you may consider, whether you are looking to light a pathway, increase your home’s security capability or add a decorative element to the home. A lighting store or home improvement center can make available all of the different low voltage lighting bulb options.
 forum activity
