Login Error
Close
3 Modern Wall Paint Color Combinations
by DoItYourself Staff
When you’re considering wall paint color, there are many different combinations you can use. Some are very traditional, especially creams and pale greens. Others are quite contemporary. Modern wall paint color combinations will work well with contemporary furniture. Get a color fan-deck from your paint store or at least a handful of paint cards in a variety of different colors. The combinations you choose are important for the look, flow and feel you want to create for your home.
TIP: Doityourself’s painting consultant Pam Estabrooke, of ProTect Painters, suggests, “Spend some time at the book store or library. There are many books available that discuss color theory and color psychology. Learn what the primary colors are. Explore complimentary color - colors located directly across from each other on the color wheel. The best known combination is green and red - Merry Christmas.”
Dark Colors
Dark colors are popular wall paint colors for modern and Victorian style decorating. They have to be used very carefully, however. There has to be ample light for this combination to work and even though the colors are dark, they should still work well together. Burgundy and grey is an excellent example of a strong dark color combination. Pick a situation where you can use a flat finish for the dark color. This results in a rich, smooth result. A satin or semi-gloss dark color will become very reflective and probably not give you the look you were going for. You can also contrast dark colors with light colors. This offers two great advantages. The light color will reflect the light into the room and it will also highlight the dark color, giving a greater dramatic impact. A royal or midnight blue with white would work well for this.
TIP: Pam says, “Color psychology is the real deal. Red is always a popular color for dining rooms and restaurants. Red is said to stimulate mood, increase appetite and aid in digestion. Conversely, red is not a good choice in a medical practice or your bedroom. Do some research and consider the mood you want in your room.”
A dark color as an accent for faux painting has become more popular recently, especially with darker greens and reds. You create a contrast by using a much lighter shade of the same color as a base and going over the top in a colorwash. This means you can have a green wall or a red wall but in different shades that provide texture and interest. Typical faux starts lighter and builds to dark using glaze and small amounts of paint.
Bright Colors
When you’re looking at wall paint color, bright primary colors can work well in a very sunny room and give a thoroughly modern slant. These can make excellent accents over a plain white wall and bold combinations of perhaps a yellow stripe and a blue stripe can be used. This way you not only add color but also design to the wall.
You can use one bright wall to stand out from three other subdued walls in a room as well. With three walls a muted off-white and the other bright green, for example, you have instantly created a talking point and the room almost becomes a piece of art in itself. You always have to be careful because bright colors can overpower a room. Use them sparingly to create the best impact and effect in wall paint color. Consider using the bright color opposite the wall with an outside light source - windows or doors. If you are trying this technique in a child’s room, the wall with the bed positioned on it is also a good choice. Break the bold color of the wall up by using large wall art or decals.
Light Colors
Light wall paint color is always advisable in a dark room to add brightness. However, that doesn’t mean you need to go for the old creams and beiges. Be bold. Choose a bright white with apricot or peach and cream for something warmer and more comforting.
TIP: Pam says, “Do not underestimate the power and impact of a monochromatic color scheme. Use splashes of one strong accent color in your accessories to give a monochromatic room a contemporary look using different shades of the same color. Meaning - stay on one color strip. Select the lightest color for the ceiling, a mid-tone for the walls and a darker shade for an accent wall. Even moving over one or two strips on the color cards can result in a bad combination.”
Use light and light colors together. If you have a room where one wall receives plenty of sun during the day, paint it a bright white and let it gleam and shine to stand out from the other walls. Paint other walls a soft, darker color and you’ll feel as if you have a brand new room. Picking colors can take a while. Be patient but don’t panic. It’s just paint. Take the time to plan the wall paint colors in your house and you’ll feel as if the house has come alive. You might even want to buy new furniture after you’ve finished.
Pam Estabrooke, district manager of ProTect Painters, contributed to this article.
 forum activity
