Login Error
Close
3 Most Popular Windshield Repair Products
by DoItYourself Staff
Windshield repair products are intended to let you make a repair to spare you the expense of completely replacing your windshield every time it get a nick or crack. To complete the repair successfully you need to know which products will work best for the type of damage that is done to your windshield. It is illegal to drive around with a windshield that is very cracked. Cracks usually start off small so it is a good idea for you to get them before they grow.
Chips and Bullseyes
Chips and bullseyes are the easiest types of fixes to make. These are a number of kits out there to make this kind of repair. Each kit will come with the suction cup, a tool and some resin. You will first need to get a razor blade and clean out all of the excess glass that is in the hole. From there, use the suction cup to clean up the damage. Make sure that you follow the instructions carefully and pay special attention that the placement of the suction kit is in the right area. If the instructions are not followed carefully, you will only have a mess on your hands.
Running Cracks
A running crack is usually a little bit more difficult to fix. A lot of kits claim that they can fix this type of crack but not all can make good on the promise. It all depends on how big the crack is and how good your kit is. It is a good idea to go online and read message board comment on the various kits before deciding which one to buy. The kits themselves will be very similar to the kits that are used for chips and bullseyes. Heavy duty kits are available for larger cracks. You may end up having to purchase a new windshield at the end of the day if the crack is too big.
Dents
You will find that dents are extremely easy to fix, if addressed as soon as they appear. Dents can make it difficult for you to see out of your windshield. They also weaken that part of the windshield and could eventually turn into chip which could eventually turn into a running crack, eventually necessitating a new windshield. Dent kits consists of suction cups that will attempt to suck the dent out.
 forum activity
