3 Necessary Septic Tank Chemicals
There are many septic tank chemicals on the market. These are usually used by homeowners because professionals do not trust their usefulness. Research has created many useful septic tank chemicals but also a few that are destructive. There isn't much proof that these septic tank chemicals will damage or harm the septic tank or its processes. You should, however, err on the side of caution when using them, and they should never be used in place of normal maintenance. The information that you will find in the following article will cover the basic septic tank chemicals most used.
1. Inorganic Compounds
Septic tank chemicals consist of caustic chemicals that are either derivatives of acids or alkalis. Chemicals that are commercially available that are used for the wellness of your plumbing contain these same chemicals. Essentially, they are used to unclog the pipes. The chemicals made for the septic tank are more powerful and will often contain lye or sulfuric acid used to eat away at organic matter. Keep in mind that these septic tank chemicals should not be used in healthy septic tanks that are not clogging or overflowing. There are many inorganic compounds that you can find on the market that are safe for new systems or are made specifically for after you repair an old system. Their purpose is to reset the chemical balance so that it can function properly and should be used every time a septic tank is emptied or a backup occurs. When looking at septic tank chemicals, make sure to avoid those that contain hydrogen peroxide if your septic tank is associated with or connected to ground water. These chemicals can harm the infiltration field. They are, however, fine to use in a contained tank system.
2. Organic Solvents
Methylene chloride and trichloroethylene are common organic additives used as solvents. These additives are often marketed as a type of degreaser that also works to break down oils. Organic solvents are very useful in promoting the proper absorption of waste, and they also promote a clean facility in which to do so. Look out for organic solvents that are not all-natural, as many of these are banned in certain states. It is these septic tank chemicals that can soak through the field and enter the groundwater, causing problems. Natural organic solvents will aid the microorganisms in the septic tank by making them more efficient during decomposition. This process is important to the stability and proper use of the septic tank. These are always best used in a septic tank system that is closed off where there is no natural drainage through the surrounding land.
3. Biological Chemicals
Septic tank chemicals that are of the biological variety are used to mirror the regular processes of the tank. They have no ill effects on the septic tank's ability to break down matter. When using these additives, always do so sparingly and according to the instructions on the package in relation to the size of your septic tank, as you could ruin the natural breakdown of waste.
