Login Error
Close
3 Options for Outdoor Party Lights
by DoItYourself Staff
If you are someone that enjoys a good time at home then consider the addition of outdoor party lights. A backyard, deck, pool barbecue area can all be enhanced with outdoor party lights. Never think of outdoor party lights as just a way to light the outside of your home but rather as a way to enhance a feeling. In the past candles, were used as an easy and inexpensive way to achieve outdoor lighting, but those days are long over. Outdoor lighting has come a long way and now there are many choices for outdoor party lights. If you want to create a fun atmosphere with your gathering then read on to discover available options for outdoor party lights.
A Perfect Luau
Summer gatherings are very popular and if you are one to have them then a luau seems like a logical choice as a party theme. Flashlights, candles and outdoor spotlights are not a way to set a proper mood at a luau. There are several options alone when wanting to throw a perfect luau. If you have multiple tables outside then you can light them with battery operated tea lights inside of carved bamboo holders, cups or mugs. You could use real candles as long as the container is large enough to contain the flame. String novelty lights are also very popular and can often be found to take on the form of various island items such as coconuts, miniature volcanoes, Easter Island statues or any other island theme or variant. If you want to go with a more authentic look, then torches are a fine choice given minimal wind and lack of dry hanging leaves or branches.
Japanese Elegance
Japanese culture is one steeped in history, honor and beauty. A sushi party is one that can be held outdoors given there is enough light to do so. Japanese outdoor party lights that you find will probably be fairly culturally authentic. Paper lanterns are use often in Japan as way to light the outdoors. These can take the form of miniature Pagoda buildings, spheres or simple paper lanterns. If you have a pond or other water treatment then you could utilize floating lanterns. Small battery operated tea lights are a safe alternative to candles.
Solar Lighting as Outdoor Party Lights
Solar lights are often used to light pathways and darkened areas. Most of the time these solar lights are able to be staked in the ground but they'll work just as well if you remove the light portion from the stake. You can string these solar lights around the backyard by tying rope, string, ribbon or twine around their centers. A simpler method would be to use removable tape strips that contain hooks. Remove the backing over the adhesive and place it on top of the solar light with the hook on top. You can then easily thread a rope through the hooks to string the solar lights together. To create colors you can tape a single piece of tissue paper to the plastic.
 forum activity
