Login Error
Close
3 Popular Tennis Racket Grip Tape Options
by DoItYourself Staff
The effectiveness of a tennis racket grip can make all the difference to how well you do in a match, which makes it prudent to be aware of the types available. By considering the different options available, you can wrap the grip of your tennis racket to ensure your game is at its best.
Absorbent
If you sweat during a tennis match and it affects your ability to hold the racket properly, you will find that an absorbent tennis racket grip tape will be beneficial. This will help to soak the moisture from your skin rather than it remaining on the surface of your palm, which can cause the racket to slip.
Padded
Choose a padded tennis racket grip tape if you suffer stiffness in your hands or simply find it uncomfortable to hold a racket for prolonged periods. Padded tape will also allow you to increase the size of the grip to make it easier to hold.
Traction
Missed shots can result from the problem of the handle of the tennis racket slipping from your grip. When this is the case, it is a good idea to use a tennis racket grip tape that can improve traction so that you can maintain a firm hold.
 forum activity
