Login Error
Close
3 Popular Themes for Bathroom Remodels
by DoItYourself Staff
Bathroom remodels are often the first kind of remodeling job a homeowner will do. Bathrooms are small spaces that you get a lot of use. Bathroom remodels are important because they can increase the value of the home. One of the greatest things about bathroom remodels is that they can take on many different types of themes and styles. The style can coincide with the home, or can differ from the style of the home. Essentially they are a space that exists outside of the rest of the house. The article that follows will provide several bathroom remodels that will not cost much money or take too much time.
Casually Elegant
This style is very clean and contemporary and can make the bathroom a strong asset. This type of style appeals to a wide range of people. Start with painting the bathroom with neutral colors. You can add a deep burgundy or royal blue to one of the walls to make the room appear larger. You can replace the countertop with a terrazzo counter to give a look of expensive marble. Beveled mirrored tile amongst dark slate tiles will provide depth and warmth.
Changing fixtures can be costly but if you do decide to go that route, then choose sleek and dynamic stainless steel or brushed nickel fixtures. Other ideas can include two-tone fixtures and pedestal sinks. Provide towels the color of the main accent tone. Add small ceramics and pharmacist jars to round out the look.
Shabby Chic
Bathroom remodels that are shabby chic tend to come from the rest of the home which is also shabby chic. The imperfect nature of the style is nostalgic and comfortable. Wooden cabinets painted white and then sanded are easy ways to create a shabby chic style.
Fixtures should be traditional with swift curves and hardware that is gold or brass can set off the style. The color scheme for shabby chic bathroom remodels are calming. Periwinkle, sage green and French blue are all possibilities. You can place artwork that is comprised of flowers or country scenes in the bathroom to go with the overall style of the room as well.
Indoor Tropical
When setting out to accomplish bathroom remodels of this type think about a basic Floridian theme; colors that are warm and bright pastels. When using these vibrant colors you should always accent them something softer; more neutral like hunter green or soft blues. You can also change the floor tile to terra cotta or bamboo and store towels in wicker baskets. Natural wood cabinets and a ceiling fan add distinctive flair.
You can go simple with the fixtures by using brass or chrome and adding glass tiles to reflect all of these colors. Add natural wood molding around the bottom and the top of the walls. You can also use wall paper stripping with bamboo trees as a repeating pattern. If you have the space to do so then include terra cotta or sandstone planters. You can increase your lighting by using LED light bulbs.
 forum activity
