3 Pros and Cons of a Wall Hung Toilet
A wall hung toilet is one that is attached to the wall of your bathroom. Wall hung toilets are a great addition to a home that has a small bathroom. The toilet has a small footprint and does not require a lot of room to be installed or used. However, while there are pros, there are also cons associated with having a wall mounted toilet in your bathroom. These pros and cons should be weighed carefully before you consider the installation of a wall hung toilet in your home.
Pros Related to Wall Hung Toilets
One benefit of a wall hung toilet is that it provides the bathroom with clean lines. The lines that are created by the wall hung toilet helps turn the bathroom into a stylish room that can complement the rest of your home's decor. This is accomplished by concealing water outlets and other aspects of the toilet that make it stick out and appear to look like an eyesore in the bathroom.
Another pro of having a wall hung toilet in your bathroom is that it takes up a minimal amount of space. Because it is hung to the wall it takes up no floor space like a conventional toilet does. This allows you to install the toilet in any convenient space near a water source in order to open up the space more for other decorating ideas.
Cons Related to Wall Hung Toilets
One of the biggest cons related to a wall hung toilet is the cost. A wall hung toilet has a greater cost than the conventional floor type toilets. This cost does not include installation and other costs associated with hanging the toilet on the wall.
A wall hung toilet can also come loose over time due to the pressure exerted on the wall mount. This may require constant adjustment and rehanging by a qualified plumber, which can become expensive. You may also experience more leaking from these toilets in comparison to the floor mounted toilets, which again will result in more repair costs.
Considering Wall Hung Toilets
Wall hung toilets are not as popular in the United States as they are in European countries. For a homeowner who chooses to have a wall hung toilet installed in their home, consideration should be given to the advantages and disadvantages of this type of toilet. If you are cost conscious buyer you may want to choose a conventional floor mounted toilet as oppose to the more expensive wall hung toilet.
Comparing costs is just one of the things that you should do before deciding on a wall hung or floor mounted toilet. Go to a kitchen and bath store and look at the different models that are available and test them out for look, feel and how it may work in your bathroom.
